- Mute
- Permalink
- Report
hello @WCrihfield
I tried the code, but just to get an error again.
I copy paste it here:
System.InvalidCastException: La conversión de la cadena "" en el tipo 'Date' no es válida.
en Microsoft.VisualBasic.CompilerServices.Conversions.ToDate(String Value)
en ThisRule.Main()
en Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
en iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
First line means "the conversion of the string "" into 'Date' type is not valid"
I think that what is failing is that in the autocad block the "SH_DATE_MODIF" may have a date, but often will be empty, and the 'date' type cannot handle the "" value?
I tried:
Case "SH_DATE_MODIF"
Try : oCProp = oCProps.Item("FECHA REVISION")
If oCProp = "" Then
Dim dModifDate As String = CDate(sValue)
Else
Dim dModifDate As Date = CDate(sValue)
End If
Catch : oCProp = oCProps.Add(dmodifdate, "FECHA REVISION") : End Try
If oCProp.Value <> dModifDate Then Try : oCProp.Value = dModifDate : Catch : End Trybut something must be wrong with the syntax or something because it gives an error as well:
Compilation errors in the rule
the variable 'dModifDate' hides a variable in an inclusion block
or something like that (it's in spanish so I tried to translate it)
On the other hand, I did manage to make the sheets change color.
PD: I just noticed as well the need to delete a block witch may be named "MARCO2000" or "Copia de MARCO2000". I tried to replicate your code but I could not make it work.
