- Mute
- Permalink
- Report
Hi @dypro. This is a fairly complex scenario, and highly custom, so I did not completely finish the code I created for it, but I got you most of the way there. There is a point down near the end of the code, where you can see that I have left you a comment to continue the pattern of code that I started, because it needs many very similar blocks of code, one for each possible 'prompt', 'value', & custom iProperty grouping. I could have created one or more externally referenced Sub/Function type routines to help eliminate some of the repetitiveness, but I decided to keep it as simple as possible for you right now, which usually means keeping it all in one logical piece, and flowing from top to bottom in one long process. I included several lines of comments, but probably could have included many more comments. If you still need help with this, feel free to post back here again.
Sub Main
'make sure we are working with a drawing...if not let user know, and exit the rule
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oACBDs As AutoCADBlockDefinitions = oDDoc.AutoCADBlockDefinitions
If oACBDs.Count = 0 Then Exit Sub 'none found in drawing, so exit the rule
'this next variable will be used to store the block definition we are trying to find, when found
Dim oTargetACBD As AutoCADBlockDefinition = Nothing
'store the two possible names of the block definition we are looking for
Dim PossibleBlockDefNames() As String = {"SH_CAR_S", "Copia de SH_CAR_S" }
'loop through the AutoCADBlockDefinitions, to find the one we are after
For Each oACBD As AutoCADBlockDefinition In oACBDs
'if the block definition is not being referenced (no placed blocks for it), try to delete it
'if an instance of it has not been placed, there will not be any values to get
If oACBD.IsReferenced = False Then Try : oACBD.Delete : Catch : End Try
'loop through the two possible names for the block definition
For Each BlockDefName In PossibleBlockDefNames
If oACBD.Name = BlockDefName Then
oTargetACBD = oACBD
Exit For 'exits this inner loop
End If
Next 'BlockDefName
If oTargetACBD IsNot Nothing Then Exit For 'exit outer loop if target already found
Next 'oACBD
If IsNothing(oTargetACBD) Then Exit Sub 'the definition was not found, so exit rule
'we must prepare the variables ahead of time, then this method fills in their values
Dim oTags() As String = {}
Dim oPrompts() As String = {}
oTargetACBD.GetPromptTags(oTags, oPrompts)
If oPrompts.Length = 0 Then Exit Sub 'the block definition does not have any prompts, so exit rule
'these next two lines are simply for research & feedback, you can comment them out if you want
oTagx = InputListBox("", oTags, "", oTargetACBD.Name & " Tags", "List Of Tags")
oPromptx = InputListBox("", oPrompts, "", oTargetACBD.Name & " Prompts", "List Of Prompts")
'get a reference to the drawing's 'Custum' iProperty set, for use later within the loop
Dim oCProps As Inventor.PropertySet = oDDoc.PropertySets.Item(4)
'now loop through the sheets to find placed blocks referencing the definition
Dim oSheets As Inventor.Sheets = oDDoc.Sheets
For Each oSheet As Inventor.Sheet In oSheets
Dim oACBs As AutoCADBlocks = oSheet.AutoCADBlocks
If oACBs.Count = 0 Then Continue For 'skip to next sheet if no blocks on this sheet
For Each oABC As AutoCADBlock In oACBs
'if the definition this block is referencing is not our 'target' one, then skip to next block
If oABC.Definition IsNot oTargetACBD Then Continue For
'again, we must prepare the variables first, then this method fills in their values
Dim oPromptTags() As String = {}
Dim oValues() As String = {}
oABC.GetPromptTextValues(oPromptTags, oValues)
If oPromptTags.Length = 0 Then Continue For 'there were no prompts, so skip to next
'again, these next two lines are simply for research & feedback
oPromptTagx = InputListBox("", oPromptTags, "", oABC.Name & " PromptTags", "List Of PromptTags")
oValuex = InputListBox("", oValues, "", oABC.Name & " Values", "List Of Values")
For i As Integer = 0 To UBound(oPromptTags)
Dim sPromptTag As String = oPromptTags(i)
Dim sValue As String = oValues(i)
Dim oCProp As Inventor.Property = Nothing
Select Case sPromptTag
Case "SH_AFFAI"
Try : oCProp = oCProps.Item("NUMERO INSTALACION")
Catch : oCProp = oCProps.Add(sValue, "NUMERO INSTALACION") : End Try
If oCProp.Value <> sValue Then Try : oCProp.Value = sValue : Catch : End Try
Case "SH_PARTI"
Try : oCProp = oCProps.Item("CODIGO DE PARTICION")
Catch : oCProp = oCProps.Add(sValue, "CODIGO DE PARTICION") : End Try
Case "SH_MODUL"
'<<<< repeat pattern of code for the rest of the prompts, values, & custom iProperties >>>>
End Select
Next 'i
'now try to delete this placed AutoCADBlock object from the sheet
Try : oABC.Delete : Catch : End Try
Next 'oABC
Next 'oSheet
'now that we have attempted to copy the needed data out,
'and have attempted to delete all of the placed blocks that reference the definition,
'we can now try to delete the block definition itself
Try : oTargetACBD.Delete : Catch : End Try
'you may need to update the drawing now
If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
'you may want to save the drawing now, but maybe not, so I left this commented out
'If oDDoc.Dirty Then oDDoc.Save2(False)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
