- Mute
- Permalink
- Report
Hi @dypro. I assume you are talking about working within an existing Inventor DrawingDocument, right? If so, is it an DWG or IDW file type? This does sound possible, because I have done some similar stuff before. You would have to provide a lot more specific details about everything involved though, before anyone would be able to generate custom code for you to accomplish this very custom task. Is the drawing one sheet, or multiple sheets? Has this block been placed on every sheet, or just on one sheet, and if just on one sheet, which sheet? Is there only one AutoCAD block in the drawing, or are there multiple? If multiple, then what is the name of that block's definition (spelling and capitalization may both be important)? What is the name (or other identifying traits) of the attribute within the block that you want to extract the value of? It may also be important for us to know how many attributes are in that block. What name do you want the new 'custom' iProperty to have? Will this iLogic rule be one that is saved within the drawing document itself, or as an external iLogic rule, that can be used on many other documents?
Wesley Crihfield
(Not an Autodesk Employee)
