05-30-2023
05:19 AM
- Mute
- Permalink
- Report
05-30-2023
05:19 AM
If you want to write a specific style in the code by name instead of selecting from a list, then you need to replace this code:
Dim oSSNames As New List(Of String) For Each oSS As DrawingStandardStyle In oSMgr.StandardStyles oSSNames.Add(oSS.Name) Next Dim oSSName As String = InputListBox("Choose Standard Style For Active Sheet", oSSNames) If oSSName = "" Then Exit Sub
with this:
Dim oSSName As String = "Name text style A"
The rule will look like this:
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "")
Exit Sub
End If
Dim oDDoc As DrawingDocument = ThisDoc.Document
Dim oSMgr As DrawingStylesManager = oDDoc.StylesManager
Dim oDSS As DrawingStandardStyle = oSMgr.StandardStyles.Item(oSSName)
Dim oSheet As Sheet = oDDoc.ActiveSheet
SetSheetStandardStyle(oSheet, oDSS)
If oDDoc.RequiresUpdate Then oDDoc.Update2(True)
'If oDDoc.Dirty Then oDDoc.Save
End Sub
Sub SetSheetStandardStyle(oSheet As Sheet, oDSS As DrawingStandardStyle)
If IsNothing(oSheet) Or IsNothing(oDSS) Then Exit Sub
Dim oDStyles As ObjectDefaultsStyle = oDSS.ActiveObjectDefaults
Dim oDDims As DrawingDimensions = oSheet.DrawingDimensions
Dim oGDims As GeneralDimensions = oDDims.GeneralDimensions
For Each oGDim As GeneralDimension In oGDims : oGDim.Style = oDStyles.LinearDimensionStyle : Next
Dim oODims As OrdinateDimensions = oDDims.OrdinateDimensions
For Each oODim As OrdinateDimension In oODims : oODim.Style = oDStyles.OrdinateDimensionStyle : Next
Dim oODSs As OrdinateDimensionSets = oDDims.OrdinateDimensionSets
For Each oODS As OrdinateDimensionSet In oODSs : oODS.Style = oDStyles.OrdinateSetDimensionStyle : Next
Dim oCDSs As ChainDimensionSets = oDDims.ChainDimensionSets
For Each oCDS As ChainDimensionSet In oCDSs : oCDS.Style = oDStyles.ChainDimensionStyle : Next
Dim oBDSs As BaselineDimensionSets = oDDims.BaselineDimensionSets
For Each oBDS As BaselineDimensionSet In oBDSs : oBDS.Style = oDStyles.BaselineDimensionStyle : Next
Dim oDNotes As DrawingNotes = oSheet.DrawingNotes
Dim oCNs As ChamferNotes = oDNotes.ChamferNotes
For Each oCN As ChamferNote In oCNs : oCN.DimensionStyle = oDStyles.ChamferNoteStyle : Next
Dim oGNs As GeneralNotes = oDNotes.GeneralNotes
For Each oGN As GeneralNote In oGNs : oGN.TextStyle = oDStyles.GeneralNoteStyle : Next
Dim oHTNs As HoleThreadNotes = oDNotes.HoleThreadNotes
For Each oHTN As HoleThreadNote In oHTNs : oHTN.Style = oDStyles.HoleNoteStyle : Next
Dim oLNs As LeaderNotes = oDNotes.LeaderNotes
For Each oLN As LeaderNote In oLNs : oLN.DimensionStyle = oDStyles.LeaderTextStyle : Next
Dim oPNs As PunchNotes = oDNotes.PunchNotes
For Each oPN As PunchNote In oPNs : oPN.DimensionStyle = oDStyles.PunchNoteStyle : Next
oSheet.Update
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
