- Mute
- Permalink
- Report
could someone assist please
I need some code that will look at an Inventor Drawing sheet and find text that uses a style (A) and change / update the text to use style (B)
- Mute
- Permalink
- Report
Hi @keithc03GZXH6 . This is code that copies the properties of one text style to another. You need to write the appropriate names for lines 4 and 5.
Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oTM As TransactionManager = ThisApplication.TransactionManager
Dim oTS As TextStylesEnumerator = oDDoc.StylesManager.TextStyles
Dim sNameTextA As String = "Name text style A"
Dim sNameTextB As String = "Name text style B"
Dim oStyleA As TextStyle = oTS.Item(sNameTextA)
Dim oStyleB As TextStyle = oTS.Item(sNameTextB)
Dim newTM As Transaction = oTM.StartTransaction(oDDoc, "ChangeTextStyle")
If oStyleA.InUse Then
oStyleA.Bold = oStyleB.Bold
oStyleA.Color = oStyleB.Color
oStyleA.Font = oStyleB.Font
oStyleA.FontSize = oStyleB.FontSize
oStyleA.HorizontalJustification = oStyleB.HorizontalJustification
oStyleA.Italic = oStyleB.Italic
oStyleA.LineSpacing = oStyleB.LineSpacing
oStyleA.Rotation = oStyleB.Rotation
oStyleA.Underline = oStyleB.Underline
oStyleA.VerticalJustification = oStyleB.VerticalJustification
oStyleA.WidthScale = oStyleB.WidthScale
End If
newTM.End()
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Andrii
the code below used to work by giving a list of the available styles but i would like to specify the style by name and not pick from a list
where / what would I change
Sub Main If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("A Drawing document must be active for this code to work. Exiting.", vbCritical, "") Exit Sub End If Dim oDDoc As DrawingDocument = ThisDoc.Document Dim oSMgr As DrawingStylesManager = oDDoc.StylesManager Dim oSSNames As New List(Of String) For Each oSS As DrawingStandardStyle In oSMgr.StandardStyles oSSNames.Add(oSS.Name) Next Dim oSSName As String = InputListBox("Choose Standard Style For Active Sheet", oSSNames) If oSSName = "" Then Exit Sub Dim oDSS As DrawingStandardStyle = oSMgr.StandardStyles.Item(oSSName) Dim oSheet As Sheet = oDDoc.ActiveSheet SetSheetStandardStyle(oSheet, oDSS) If oDDoc.RequiresUpdate Then oDDoc.Update2(True) 'If oDDoc.Dirty Then oDDoc.Save End Sub Sub SetSheetStandardStyle(oSheet As Sheet, oDSS As DrawingStandardStyle) If IsNothing(oSheet) Or IsNothing(oDSS) Then Exit Sub Dim oDStyles As ObjectDefaultsStyle = oDSS.ActiveObjectDefaults Dim oDDims As DrawingDimensions = oSheet.DrawingDimensions Dim oGDims As GeneralDimensions = oDDims.GeneralDimensions For Each oGDim As GeneralDimension In oGDims : oGDim.Style = oDStyles.LinearDimensionStyle : Next Dim oODims As OrdinateDimensions = oDDims.OrdinateDimensions For Each oODim As OrdinateDimension In oODims : oODim.Style = oDStyles.OrdinateDimensionStyle : Next Dim oODSs As OrdinateDimensionSets = oDDims.OrdinateDimensionSets For Each oODS As OrdinateDimensionSet In oODSs : oODS.Style = oDStyles.OrdinateSetDimensionStyle : Next Dim oCDSs As ChainDimensionSets = oDDims.ChainDimensionSets For Each oCDS As ChainDimensionSet In oCDSs : oCDS.Style = oDStyles.ChainDimensionStyle : Next Dim oBDSs As BaselineDimensionSets = oDDims.BaselineDimensionSets For Each oBDS As BaselineDimensionSet In oBDSs : oBDS.Style = oDStyles.BaselineDimensionStyle : Next Dim oDNotes As DrawingNotes = oSheet.DrawingNotes Dim oCNs As ChamferNotes = oDNotes.ChamferNotes For Each oCN As ChamferNote In oCNs : oCN.DimensionStyle = oDStyles.ChamferNoteStyle : Next Dim oGNs As GeneralNotes = oDNotes.GeneralNotes For Each oGN As GeneralNote In oGNs : oGN.TextStyle = oDStyles.GeneralNoteStyle : Next Dim oHTNs As HoleThreadNotes = oDNotes.HoleThreadNotes For Each oHTN As HoleThreadNote In oHTNs : oHTN.Style = oDStyles.HoleNoteStyle : Next Dim oLNs As LeaderNotes = oDNotes.LeaderNotes For Each oLN As LeaderNote In oLNs : oLN.DimensionStyle = oDStyles.LeaderTextStyle : Next Dim oPNs As PunchNotes = oDNotes.PunchNotes For Each oPN As PunchNote In oPNs : oPN.DimensionStyle = oDStyles.PunchNoteStyle : Next oSheet.Update End Sub
- Mute
- Permalink
- Report
If you want to write a specific style in the code by name instead of selecting from a list, then you need to replace this code:
with this:
Dim oSSName As String = "Name text style A"
The rule will look like this:
Sub Main
Exit Sub
End If
End Sub
oSheet.Update
End Sub
