05-29-2023
12:25 PM
- Mute
- Permalink
- Report
05-29-2023
12:25 PM
I changed the code a bit and you should not get the exception any more. About the styles; the code uses your default drawing template I guess you use another template. In the code a line (6) where you can set the full file name of the template that you want to use.
Sub Main()
Dim doc As AssemblyDocument = ThisDoc.Document
Dim def As AssemblyComponentDefinition = doc.ComponentDefinition
' Change this if you dont want to use the default template
Dim templateFileName As String = ""
Dim dDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templateFileName)
Dim sheet As Sheet = dDoc.ActiveSheet
FillSheet(sheet, doc)
For Each refDoc As Document In doc.AllReferencedDocuments
Dim newSHeet = dDoc.Sheets.Add()
FillSheet(newSHeet, refDoc)
Next
End Sub
Private Sub FillSheet(sheet As Sheet, doc As Document)
sheet.Name = doc.DisplayName
Dim sheetW4 = sheet.Width / 4
Dim sheetH4 = sheet.Height / 4
Try
Dim position As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(sheetW4, sheetH4)
Dim baseView As DrawingView = sheet.DrawingViews.AddBaseView(doc, position, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim scale = CalculateScale(baseView)
baseView.Scale = scale
position = ThisApplication.TransientGeometry.CreatePoint2d(sheetW4 * 3, sheetH4)
Dim view = sheet.DrawingViews.AddProjectedView(baseView, position, DrawingViewStyleEnum.kFromBaseDrawingViewStyle, scale)
scale = Math.Min(scale, CalculateScale(view))
position = ThisApplication.TransientGeometry.CreatePoint2d(sheetW4, sheetH4 * 3)
position = ThisApplication.TransientGeometry.CreatePoint2d(sheetW4 * 3, sheetH4 * 3)
view.Scale = scale
Catch ex As Exception
MsgBox("Something went wrong while creating sheet for model: " & doc.DisplayName)
Return
End Try
End Sub
Private Function CalculateScale(view As DrawingView) As Double
Dim scaleX = view.Parent.Width / view.Width / 2
Dim scaleY = view.Parent.Height / view.Height / 2
Return Math.Min(scaleX, scaleY)
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
