Andrii_Humeniuk
in reply to: karram
Try this code.
Sub main
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If TypeOf oDoc Is AssemblyDocument Then
		Dim oCM As CommandManager = ThisApplication.CommandManager
		Dim oTm As TransactionManager = ThisApplication.TransactionManager
		Dim oADoc As AssemblyDocument = oDoc
		Dim oCompCopy, oCompPaste As ComponentOccurrence
		Do
			oCompCopy = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component copy params...")
			If oCompCopy Is Nothing Then Exit Sub
			If oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
			oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then GoTo Step1Rule
		Loop
		Step1Rule :
		Do
			oCompPaste = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component paste params...")
			If oCompPaste Is Nothing Then Exit Sub
			If oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
			oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then GoTo Step2Rule
		Loop
		Step2Rule :
		Dim newTM As Transaction = oTm.StartTransaction(oADoc, "CopingUserParameters")
		Call CreateParamsInAssembly(oCompPaste.Definition.Parameters, oCompCopy.Definition.Parameters)
		newTM.End()
		oADoc.Update()
	Else
		MessageBox.Show("Active document is not AssemblyDocument.", "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
	End If
End Sub
Private Function CreateParamsInAssembly(oParams As Parameters, ByVal copyParams As Parameters)
	Dim bCreatParam As Boolean
	For Each copyParam As UserParameter In copyParams.UserParameters
		bCreatParam = True
		For Each oParam As UserParameter In oParams.UserParameters
			If oParam.Name = copyParam.Name Then
				bCreatParam = False
				Try
					oParam.Value = copyParam.Value
				Catch
					oParam.Expression = copyParam.Expression
				End Try
			End If
		Next
		If bCreatParam Then
			oParams.UserParameters.AddByExpression(copyParam.Name, copyParam.Expression, copyParam.Units)
		End If
	Next
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
