- Mute
- Permalink
- Report
Using ilogic how to copy user parameters from one assembly file to another assembly files.
For Example Assembly file (Test_A.iam) contains 10 user parameter. using ilogic i need to copy automatically all user parameters to another assembly file (Test_B.iam).
- Mute
- Permalink
- Report
Hi @karram . Try this code. You need to select 2 assemblage either in the model or in the browser. The first click on the assembly from which you will copy parameters, the second click on the assembly in which you will create parameters.
Sub main
Dim oDoc As Document = ThisApplication.ActiveDocument
If TypeOf oDoc Is AssemblyDocument Then
Dim oCM As CommandManager = ThisApplication.CommandManager
Dim oTm As TransactionManager = ThisApplication.TransactionManager
Dim oADoc As AssemblyDocument = oDoc
Dim oCompCopy, oCompPaste As ComponentOccurrence
Do
oCompCopy = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select assembly copy params...")
If oCompCopy Is Nothing Then Exit Sub
Loop While oCompCopy.DefinitionDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject
Do
oCompPaste = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select assembly paste params...")
If oCompPaste Is Nothing Then Exit Sub
Dim newTM As Transaction = oTm.StartTransaction(oADoc, "CreateUserParameters")
Dim listParams As New List(Of UserParameter)
listParams = GetListParams(oCompCopy.Definition.Parameters)
Call CreateParamsInAssembly(oCompPaste.Definition.Parameters, listParams)
newTM.End()
oADoc.Update()
Else
MessageBox.Show("Active document is not AssemblyDocument.", "Error!",MessageBoxButtons.OK,MessageBoxIcon.Error)
End If
End Sub
Private Function CreateParamsInAssembly(oParams As Parameters, ByVal listParams As List(Of UserParameter))
Dim bCreatParam As Boolean = True
For i As Integer = 1 To listParams.Count
For Each oParam As UserParameter In oParams.UserParameters
If oParam.Name = listParams.Item(i - 1).Name Then
bCreatParam = False
Try
oParam.Value = listParams.Item(i - 1).Value
Catch
oParam.Expression = listParams.Item(i - 1).Expression
End Try
End If
Next
If bCreatParam Then
oParams.UserParameters.AddByExpression(listParams.Item(i - 1).Name, listParams.Item(i - 1).Expression, listParams.Item(i - 1).Units)
End If
Next i
End Function
Private Function GetListParams(ByVal oParams As Parameters) As List(Of UserParameter)
listParams.Add(oParam)
Next
Return listParams
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
- Mute
- Permalink
- Report
Above code works perfect, Thanks.
Is there any option how to copy user parameters from one Part to another parts and also copy user parameters from one Part to Assembly like same above code.
- Mute
- Permalink
- Report
Hi @karram . Try this code. It can copy in any combination: Assembly - Assembly, Assembly - Detail, Detail - Detail, Detail - Assembly.
Sub main
Do
oCompCopy = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component copy params...")
Loop While Not oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject
Do
oCompPaste = oCM.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select component paste params...")
Loop While Not oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject
Dim newTM As Transaction = oTm.StartTransaction(oADoc, "CopingUserParameters")
Call CreateParamsInAssembly(oCompPaste.Definition.Parameters, oCompCopy.Definition.Parameters)
newTM.End()
oADoc.Update()
Else
End If
End Sub
Private Function CreateParamsInAssembly(oParams As Parameters, ByVal copyParams As Parameters)
For Each copyParam As UserParameter In copyParams.UserParameters
bCreatParam = True
If oParam.Name = copyParam.Name Then
bCreatParam = False
Try
oParam.Value = copyParam.Value
Catch
oParam.Expression = copyParam.Expression
End Try
End If
Next
If bCreatParam Then
oParams.UserParameters.AddByExpression(copyParam.Name, copyParam.Expression, copyParam.Units)
End If
Next
End Function
- Mute
- Permalink
- Report
Above code woks only Assembly-Assembly combination.
Above code Not works for following combination Parts - Parts, Part -Assembly, Assembly-parts.
- Mute
- Permalink
- Report
Try this code.
Sub main
Do
If oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
oCompCopy.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then GoTo Step1Rule
Loop
Step1Rule :
Do
If oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
oCompPaste.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then GoTo Step2Rule
Loop
Step2Rule :
newTM.End()
oADoc.Update()
Else
End If
End Sub
bCreatParam = True
bCreatParam = False
Try
Catch
End Try
End If
Next
If bCreatParam Then
End If
Next
End Function
