WCrihfield
in reply to: ldellaversano
Hi @ldellaversano.  It is very difficult to determine what may be going wrong just based on the information you provided.  If the error happens again, can you look at the 'More Info' tab of the error message that shows, and translate that to English for us.  If you just take a screenshot of the error message, it will still be in be in your native language, and some of us will not be able to read it or translate it.  Usually there is a line of text within the 'More Info' tab that indicates what it was trying to do when the error was encountered, and we can use that to determine where in your code the error occurred.  But even that may not help if we can not see your code.  I suspect, based on your description that this may be a simple matter of needing to update the document after making some edits before trying to change the feature names again, but it is very difficult to judge on so little information.  Please include as much information as possible.
Wesley Crihfield
(Not an Autodesk Employee)
