- Mute
- Permalink
- Report
Crash (Endless loop) on any iteract to non-First row of DataGridView
(this thread seems related to general programming but as soon as I suffer the issue in context of Inventor-relatad project I hope it is not too-much off-topic here)
In one of my Inventor-related projects I'd like to provide user with Windows Form containing controls of some options (CheckBoxes) organized with DataGridView.
Here is a very simplified (Paint-created) version of the desired form:
Pay attention there are some <empty> (not an option) cells.
The hard thing of this task - irregularity of the CheckBoxCell pattern (should be generated dynamically according to some business logic that is not an object of this thread).
Initially I thought I need to use Boolean type for Columns where CheckBoxes are to be placed but that seems to be the wrong way (AFAIK CheckBoxCell can't be converted to an <empty cell>, at least all my attempts to do so were unsuccessful, see commented).
Then I search Internet a bit and found a mention that opposite conversation (from TextBoxCell to CheckBoxCell is possible).
Using this knowledge I get some progress towards the desired.
Now I can convert <empty cell> to checkbox with following iLogic code (see the DataBindingComplete sub):
Option Explicit On
AddReference "System.Data"
AddReference "System.Xml"
Imports System.Data
Imports System.Windows.Forms
Class AAA
Friend WithEvents oDGV As New DataGridView
Dim sHeader1 As String = "Name"
Dim sHeader2 As String = "Option1"
Dim sHeader3 As String = "Option2"
Sub Main
Dim oDT As DataTable = New DataTable
oDT.Columns.Add(sHeader1, GetType(String))
oDT.Columns.Add(sHeader2, GetType(String)) ' GetType(Boolean))
oDT.Columns.Add(sHeader3, GetType(String)) ' GetType(Boolean))
Dim names = New List(Of String)
names.Add("A1")
names.Add("A2")
' Dim opt1vals = New List(Of String)
' opt1vals.Add(False)
' opt1vals.Add(True)
' Dim opt2vals = New List(Of String)
' opt2vals.Add(True)
' opt2vals.Add(False)
Dim i As Integer = 0
For Each name in Names
oDT.Rows.Add(oDT.Columns.Count)
oDT.Rows(i)(sHeader1) = name
' oDT.Rows(i)(sHeader2) = opt1vals(i)
' oDT.Rows(i)(sHeader3) = opt2vals(i)
i +=1
Next
Dim oDV As DataView = oDT.DefaultView
With oDGV
.AllowUserToAddRows = False
.AutoSize = True
.DataSource = oDV
End With
Dim oForm As New Form
With oForm
.AutoSize = True
.Controls.Add(oDGV)
End With
' logger.info("oDGV.Rows.Count #1 = " & oDGV.Rows.Count)
oForm.ShowDialog()
End Sub
Sub oDGV_DataBindingComplete(ByVal sender As Object, ByVal E As DataGridViewBindingCompleteEventArgs) Handles oDGV.DataBindingComplete
logger.info("oDGV.Rows.Count #2 = " & oDGV.Rows.Count)
oDGV.Rows(0).Cells(sHeader3).Value = True
oDGV.Rows(0).Cells(sHeader3) = New DataGridViewCheckBoxCell()
' oDGV.Rows(1).Cells(sHeader2).Value = True ' !!! ENDLESS-LOOP
' oDGV.Rows(1).Cells(sHeader2) = New DataGridViewCheckBoxCell()
End Sub
' Sub oDGV_DataBindingComplete(ByVal sender As Object, ByVal E As DataGridViewBindingCompleteEventArgs) Handles oDGV.DataBindingComplete
' logger.info("oDGV.Rows.Count-2 = " & oDGV.Rows.Count)
' oDGV.Rows(0).Cells(sHeader2).Value = False
' oDGV.Rows(0).Cells(sHeader2) = New DataGridViewTextBoxCell()
' oDGV.Rows(0).Cells(sHeader2).Value = ""
' End Sub
End Class
BUT for some reason this behaves as expected ONLY for cells of the first row (row index = 0).
As soon as I try to do this for a cell in the second row (row index = 1) the code crashes (after some time of endless cycling ... which I detect by means of iLogic Log panel).
But the problem seems not the conversation itself ... the code goes to endless cycle even if I comment-out those two lines related to the second row but try to interact with any cell of second row!
What I'm missing?
Please vote for Inventor-Idea Text Search within Option Names
