alex.van.canneyt
327 Views, 3 Replies
Change internal mapping of 3D parts
Hello
Im trying to understand how this principle works in Inventor.
Case:
We have 2 different bolts, 1 is constrained in an assembly.
Example of how this could be constrained, 2 red planes coincident, 2 coincident axises.
Now we want to replace this bolt with a bigger one, so we replace the part in the assembly.
The result is this:
My question is:
How can we edit the second bolt so that is has the same position as the first bolt when replaced in the assembly?
- Can we rename the internal parameter from edges/planes to same one as the first bolt?
- Do we just need to make sure the XYZ matches?
- does autodesk has tools to edit the part references?
- Any ilogic solutions?
I did not find any topics regarding this issue.
I want to know this to correct legacy data. I want to know what the limitations are on this subject.
Thanks!
