Hi @tucker.smithAKU2X
Remove the declaration of variable name. Or set them equal to the parameter. As it is this is setting up a variable name with no assigned value.
Code with local parameter as values.
'machineName = "PRESS"
'machineNumber = 103 ul
'workCenterNumber = 6310 ul
Dim machineName As String = machineName
Dim machineNumber As String = machineNumber
Dim workCenterNumber As String = workCenterNumber
ThisDoc.Document.SaveAs(machineNumber & machineName & ".stl" , True)
Regards
Alan
