tucker.smithAKU2X
319 Views, 4 Replies
user parameter not going to file name when using SaveAS
this code works to save my file as an stl, but the only thing i see in windows explorer is a file that is created as just .stl. i know i have values in my parameters, but i do not know why it won't pass it to actually create a file name. code is
'machineName = "PRESS"
'machineNumber = 103 ul
'workCenterNumber = 6310 ul
Dim machineName As String
Dim machineNumber As String
Dim workCenterNumber As String
ThisDoc.Document.SaveAs(machineNumber & machineName & ".stl" , True)
Hi @tucker.smithAKU2X
Remove the declaration of variable name. Or set them equal to the parameter. As it is this is setting up a variable name with no assigned value.
Code with local parameter as values.
Dim machineName As String = machineName
Dim machineNumber As String = machineNumber
Dim workCenterNumber As String = workCenterNumber
Regards
Alan
It still saves as just .stl with no file name.
ThisDoc.Document.SaveAs(machineNumber & machineName & workCenterNumber & ".stl", True)
Just tested this so either change the variable name or remove the variable like below.
Remove String variable
MessageBox.Show(machineNumber & machineName & ".stl", "Title")
 Change String variable name
Dim smachineName As String = machineName
Dim smachineNumber As String = machineNumber
Dim sworkCenterNumber As String = workCenterNumber
MessageBox.Show(smachineNumber & smachineName & ".stl", "Title")
Regards
Alan
Thank you so much for your help!
