emanuel.c
in reply to: WCrihfield
I modified the main Sub with this and it seems to work now, by counting only the Visible rows.
If you have any input, to make it simpler or better please share it. I always appreciate it!
Sub Main()
	If Not ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
		MessageBox.Show("Hey this rule only runs in drawing documents!")
		Exit Sub
	End If
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	Dim oSheets As Inventor.Sheets = oDrawDoc.Sheets
	Dim oLongestPL As PartsList = Nothing
	Dim iMostRows As Integer = 0
	Dim iSheetNumber As Integer = 0
	For Each oSheet As Inventor.Sheet In oSheets
		Dim oPLs As PartsLists = oSheet.PartsLists
		If oPLs.Count = 0 Then Continue For
		For Each oPL As PartsList In oPLs
			Dim i As Long
			Dim oVisibleRows As Integer = 0
			For i = 1 To oPL.PartsListRows.Count
				Dim oRow As PartsListRow
				oRow = oPL.PartsListRows.Item(i)
				If oRow.Visible = True Then
					oVisibleRows = oVisibleRows + 1
				End If
			Next
			If oVisibleRows > iMostRows Then
				iMostRows = oPL.PartsListRows.Count
				oLongestPL = oPL
				iSheetNumber = CInt(oSheet.Name.Split(":").Last)
			End If
		Next
	Next
	ExportPartsList(oDrawDoc, oLongestPL)
End Sub
