Hi @anavazquez5LRNJ.  I am a little confused about what your actual goal is in this post.  I think you may need to include a lot more details and/or explain much more specifically what all you are trying to accomplish.  Can you do what you want to do manually, but are trying to do it by code instead?  If so, how do you currently do it manually?  Are you trying to copy Parameter Type objects from a model document to a drawing document?  Are you trying to create DrawingDimensions on a Sheet in a DrawingDocument?
What version of Inventor are you using?  In some situations you can simply retrieve model dimensions directly into a drawing view using tools already available in Inventor's user interface, manually.  When a drawing view contains an assembly, and you are trying to access things that are unique to just one component within that assembly, that can really complicate the efforts of doing things by code.
Wesley Crihfield
(Not an Autodesk Employee)
