anavazquez5LRNJ
321 Views, 3 Replies
Place a dimension on a drawing
I don't know if it is possible to place a dimension on an assembly by clicking on an occurrence,
I don't know if it is possible to automate the measurements in the drawing without using Workplanes or Workpoint I just need to find a way to send the parameters (length and width) to text or to send them directly to the drawing.
This is the code I have been working with:
Dim oDrawcurveSeg As DrawingCurveSegment
oDrawcurveSeg = ThisApplication.CommandManager.Pick( Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawingCurve")
  ' Get the parent DrawingCurve
    Dim oDrawCurve As DrawingCurve
    oDrawCurve = oDrawcurveSeg.Parent
    ' Get the model geometry this curve represents.
    Dim oModelGeom As Object
        oModelGeom = oDrawCurve.ModelGeometry
    ' Check to see if the returned object supports
    ' the ContainingOccurrence property.
    Dim oOccurrence As ComponentOccurrence
    oOccurrence = oModelGeom.ContainingOccurrence
    Dim oModelGeometry = oDrawcurveSeg.Parent.ModelGeometry
    Dim oCompDef As ComponentDefinition
    oCompDef = oModelGeometry.Parent.Componentdefinition
    partNameToTest = oCompDef.Document.DisplayName
	Dim parametroWidth As String = Parameter(partNameToTest, "Width")
	Dim parametroLength As String = Parameter( partNameToTest, "Length")
MessageBox.Show(partNameToTest & vbCrLf & "Width:" & parametroWidth & vbCrLf & "Length:" & parametroLength)
This is an example of what I'd like to get to, I've been looking for more but haven't found much.
