J.VandeMerckt
759 Views, 8 Replies
How to Save copy as, straight into vault
Hi Forum
I have this line of code which saves my configurable part with a custom filename.
It works as intended.
Problem is I would like this file to be checked into the vault instead of saved in file explorer.
Can anyone help me change the code so the part is also checked into the vault.
Dim currentfilename As String
Dim choice As String
Dim length As String
currentfilename = ThisDoc.FileName(False)
choice = Parameter("FixedUnit_Curve")
length = Parameter("FixedUnit_Length")
'custom filepath
'SetTheFilePathHere = "C:\ ... your filepath ..."
'filepath same as the current ipt
SetTheFilePathHere = ThisDoc.Path
SetTheFilenameHere = currentfilename & " - " & choice & " - L" & length & "mm"
ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".ipt")
Dim oCtrlDef
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd")
oCtrlDef.Execute
 Thank you for helping.
BR
Justin
