- Mute
- Permalink
- Report
Hi Forum
I have this line of code which saves my configurable part with a custom filename.
It works as intended.
Problem is I would like this file to be checked into the vault instead of saved in file explorer.
Can anyone help me change the code so the part is also checked into the vault.
Dim currentfilename As String Dim choice As String Dim length As String currentfilename = ThisDoc.FileName(False) choice = Parameter("FixedUnit_Curve") length = Parameter("FixedUnit_Length") 'custom filepath 'SetTheFilePathHere = "C:\ ... your filepath ..." 'filepath same as the current ipt SetTheFilePathHere = ThisDoc.Path SetTheFilenameHere = currentfilename & " - " & choice & " - L" & length & "mm" ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".ipt") Dim oCtrlDef oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd") oCtrlDef.Execute
Thank you for helping.
BR
Justin
- Mute
- Permalink
- Report
oCtrlDef.Execute
Dim oCtrlDefChin
oCtrlDefChin = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
oCtrlDefChin.Execute '.Execute2(True)
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Now the checkin window opens. but only after I close my form.
is there a way to close the form after the Ilogic ran, and then press ok automatically on the checkin window?
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
What version of Vault are you using?
Professional
Basic
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Arthur Knoors
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
With Vault Professional it is possible yes.
Arthur Knoors
