04-16-2023
09:44 AM
- Mute
- Permalink
- Report
04-16-2023
09:44 AM
I believe you have it present because you've installed SDK-UserTools* (C:\Users\Public\Documents\Autodesk\Inventor 2023\SDK\UserTools.MSI), right?
This does not install the add-in if i am right. this only unpack the vb.net projects.
Did not install that. I still think it comes shipped with inventor.
Arthur Knoors
Autodesk Affiliations:
