Hi there,
I would try the following:
Dim currentfilename As String
Dim choice As String
Dim length As String
currentfilename = ThisDoc.FileName(False)
choice = Parameter("FixedUnit_Curve")
length = Parameter("length")
'custom filepath
'SetTheFilePathHere = "C:\ ... your filepath ..."
'filepath same as the current ipt
SetTheFilePathHere = ThisDoc.Path
SetTheFilenameHere = currentfilename & " " & choice & " " & length
ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, SetTheFilePathHere &"\" & SetTheFilenameHere & ".ipt")
Dim oCtrlDef
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileSaveCopyAsCmd")
oCtrlDef.Execute
I assume that you are using a custom Parameter for the length as well? If that's the case you have to edit the parameter name in Line 9 to the one you are using.
Let me know if it worked :slightly_smiling_face:
