04-11-2023
06:01 AM
- Mute
- Permalink
- Report
04-11-2023
06:01 AM
Total Lenght of 2d and 3d sketch, Possible?
I have this code that can add all lenght of 2d sketch into a total length. this code does not work with a 3d skecth, can I make a code that work with 3d sketch ? I want to make an content center part for hoses, but I need the total lenght as a properties G_L for our ERP system
Try
'Find content center family name
oDoc =ThisDoc.Document
Dim family = oDoc.PropertySets("{B9600981-DEE8-4547-8D7C-E525B3A1727A}")("Family").Value
If family = "Timing belt" Then
'Get sketch with loop
Dim oSketch As Sketch = ThisDoc.Document.ComponentDefinition.Sketches("Tooth Belt path")
Dim loopLength As Double = 0
'Iterate all sketch entities
For Each entity As SketchEntity In oSketch.SketchEntities
'Skip construction entities
If entity.Construction Then Continue For
Try
'Get entity length when possible
Dim entityLength As Double
entityLength = entity.Length
'Add entity length to loop length
loopLength = loopLength + entityLength
Catch
'Ignore entities without length
'For eaxample SketchPoint hasn't length
Continue For
End Try
Next
'Use result in mm
Parameter("G_L") = loopLength * 10
End If
Catch
End Try
