04-10-2023
08:06 AM
- Mute
- Permalink
- Report
04-10-2023
08:06 AM
This iLogic rule is taken from my blog post "Automatically generate overall dimensions". It will add the outer dimensions to a drawing view that you select.
On my blog you will also find iLogic rules for "Automatically generate hole position dimensions", "Automatically generate bend dimensions", and many other tools
Public Class ThisRule
' This code was written by Jelte de Jong
' and published on www.hjalte.nl
Private _doc As DrawingDocument
Private _sheet As Sheet
Private _view As DrawingView
Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
Sub Main()
_doc = ThisDoc.Document
_sheet = _doc.ActiveSheet
_view = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kDrawingViewFilter,
"Select a drawing view")
CreateIntentList()
createHorizontalOuterDimension()
createVerticalOuterDimension()
End Sub
Private Sub createHorizontalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
Dim pointLeft = orderedIntents.First
Dim pointRight = orderedIntents.Last
Dim textX = pointLeft.PointOnSheet.X +
(pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
Dim textY = _view.Position.Y + _view.Height / 2 + 2
Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
_sheet.DrawingDimensions.GeneralDimensions.AddLinear(
pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
End Sub
Private Sub createVerticalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
Dim pointLeft = orderedIntents.Last
Dim pointRight = orderedIntents.First
Dim textY = pointLeft.PointOnSheet.Y +
(pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
Dim textX = _view.Position.X - _view.Width / 2 - 2
pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
End Sub
Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
If intent.PointOnSheet Is Nothing Then Return
If onLineCheck Then
If (IntentIsOnCurve(intent)) Then
_intents.Add(intent)
End If
Else
End If
End Sub
Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
Dim Geometry As DrawingCurve = intent.Geometry
Dim sp = intent.PointOnSheet
Dim pts(1) As Double
Dim gp() As Double = {}
Dim md() As Double = {}
Dim pm() As Double = {}
Dim st() As SolutionNatureEnum = {}
pts(0) = sp.X
pts(1) = sp.Y
Try
Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
Catch ex As Exception
Return False
End Try
Return True
End Function
Private Sub CreateIntentList()
For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
Select Case oDrawingCurve.ProjectedCurveType
Case _
Curve2dTypeEnum.kCircleCurve2d,
Curve2dTypeEnum.kCircularArcCurve2d,
Curve2dTypeEnum.kEllipseFullCurve2d,
Curve2dTypeEnum.kEllipticalArcCurve2d
addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
Case _
Curve2dTypeEnum.kLineCurve2d,
Curve2dTypeEnum.kLineSegmentCurve2d
Case _
Curve2dTypeEnum.kPolylineCurve2d,
Curve2dTypeEnum.kBSplineCurve2d,
Curve2dTypeEnum.kUnknownCurve2d
' Unhandled curves types
Case Else
End Select
Next
End Sub
' Copyright 2021
' This code was written by Jelte de Jong, and published on www.hjalte.nl
' Permission Is hereby granted, free of charge, to any person obtaining a copy of this
' software And associated documentation files (the "Software"), to deal in the Software
' without restriction, including without limitation the rights to use, copy, modify, merge,
' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons
' to whom the Software Is furnished to do so, subject to the following conditions:
' The above copyright notice And this permission notice shall be included In all copies Or
' substantial portions Of the Software.
' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED,
' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR
' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE
' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or
' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER
' DEALINGS In THE SOFTWARE.
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
