orhan.alihanov
309 Views, 2 Replies
Dimension line
Hello! I have an easy problem that I can't seem to solve. Please help me to add a dimension line for dimensions to the view. From the leftmost point to the rightmost one, for example.
Dim invApp As Inventor.Application
invApp = ThisApplication
Dim partDoc As PartDocument = ThisDoc.Document
Dim tg As TransientGeometry = ThisApplication.TransientGeometry
' Определение пути к шаблону
Dim templatePath As String
templatePath = ".\Templates\Standard.dwg"
Dim newDrawingDoc As DrawingDocument
newDrawingDoc = invApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templatePath, True)
newDrawingDoc.Activate()
Dim oSheet As Sheet = newDrawingDoc.ActiveSheet
Dim frontView As DrawingView
frontView = oSheet.DrawingViews.AddBaseView(partDoc, tg.CreatePoint2d(x,y), 1/50, ViewOrientationTypeEnum.kBackViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
This iLogic rule is taken from my blog post "Automatically generate overall dimensions". It will add the outer dimensions to a drawing view that you select.
On my blog you will also find iLogic rules for "Automatically generate hole position dimensions", "Automatically generate bend dimensions", and many other tools
Public Class ThisRule
	' This code was written by Jelte de Jong
	' and published on www.hjalte.nl
    Private _doc As DrawingDocument
    Private _sheet As Sheet
    Private _view As DrawingView
    Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
    Sub Main()
        _doc = ThisDoc.Document
        _sheet = _doc.ActiveSheet
        _view = ThisApplication.CommandManager.Pick(
                       SelectionFilterEnum.kDrawingViewFilter,
                       "Select a drawing view")
        CreateIntentList()
        createHorizontalOuterDimension()
        createVerticalOuterDimension()
    End Sub
    Private Sub createHorizontalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
        Dim pointLeft = orderedIntents.First
        Dim pointRight = orderedIntents.Last
        Dim textX = pointLeft.PointOnSheet.X +
                (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
        Dim textY = _view.Position.Y + _view.Height / 2 + 2
        Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
        _sheet.DrawingDimensions.GeneralDimensions.AddLinear(
            pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
    End Sub
    Private Sub createVerticalOuterDimension()
        Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
        Dim pointLeft = orderedIntents.Last
        Dim pointRight = orderedIntents.First
        Dim textY = pointLeft.PointOnSheet.Y +
                (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
        Dim textX = _view.Position.X - _view.Width / 2 - 2
            pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
    End Sub
    Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
        Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
        If intent.PointOnSheet Is Nothing Then Return
        If onLineCheck Then
            If (IntentIsOnCurve(intent)) Then
                _intents.Add(intent)
            End If
        Else
        End If
    End Sub
    Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
        Dim Geometry As DrawingCurve = intent.Geometry
        Dim sp = intent.PointOnSheet
        Dim pts(1) As Double
        Dim gp() As Double = {}
        Dim md() As Double = {}
        Dim pm() As Double = {}
        Dim st() As SolutionNatureEnum = {}
        pts(0) = sp.X
        pts(1) = sp.Y
        Try
            Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
        Catch ex As Exception
            Return False
        End Try
        Return True
    End Function
    Private Sub CreateIntentList()
        For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
            Select Case oDrawingCurve.ProjectedCurveType
                Case _
                        Curve2dTypeEnum.kCircleCurve2d,
                        Curve2dTypeEnum.kCircularArcCurve2d,
                        Curve2dTypeEnum.kEllipseFullCurve2d,
                        Curve2dTypeEnum.kEllipticalArcCurve2d
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
                    addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
                    addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
                Case _
                        Curve2dTypeEnum.kLineCurve2d,
                        Curve2dTypeEnum.kLineSegmentCurve2d
                Case _
                    Curve2dTypeEnum.kPolylineCurve2d,
                    Curve2dTypeEnum.kBSplineCurve2d,
                    Curve2dTypeEnum.kUnknownCurve2d
                    ' Unhandled curves types
                Case Else
            End Select
        Next
    End Sub
    ' Copyright 2021
    ' This code was written by Jelte de Jong, and published on www.hjalte.nl
    ' Permission Is hereby granted, free of charge, to any person obtaining a copy of this
    ' software And associated documentation files (the "Software"), to deal in the Software
    ' without restriction, including without limitation the rights to use, copy, modify, merge,
    ' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons
    ' to whom the Software Is furnished to do so, subject to the following conditions:
    ' The above copyright notice And this permission notice shall be included In all copies Or
    ' substantial portions Of the Software.
    ' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED,
    ' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR
    ' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE
    ' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or
    ' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER
    ' DEALINGS In THE SOFTWARE.
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
