ColdWatermelonJuice
914 Views, 7 Replies
Is it possible to use "AddVBFile" in Straight VB Code File?
Hi all,
I am trying to call a sub, which is declared in a class from a separate VB file, and this sub also calls another sub from a module declared in another separate VB file.
To summarise, I have a total of three VB files, and all of them are stored under the iLogic external rule directory.
The code is shown below.
File: Code.vb
AddVbFile "ExternalClass.vb"
Sub Main()
    ClassA.MSGC()
End Sub
File: ExternalClass.vb
AddVbFile "ExternalModule.VB"
Public Class ClassA
    Public Shared Sub MSGC()
        System.Windows.Forms.MessageBox.Show("Call from ClassA")
        ModuleB.MSGM()
    End Sub
End Class
File: ExternalModule.vb
Public Module ModuleB
    Public Sub MSGM()
        System.Windows.Forms.MessageBox.Show("Call from ModuleB")
    End Sub
End Module
After I ran the Code.vb file. I got the following error message.
Rule Compile Errors in Code, in Part1
Error on Line 1 : Declaration expected.
Error on Line 7 : 'ModuleB' is not declared. It may be inaccessible due to its protection level.
I think Line 1 and Line 7 refer to lines in ExternalClass.vb.
My induction is that straight vb code does not support AddVBFile as it's for ilogic only.
My programming knowledge is very limited, and I do not know how to set up a code that is equivalent to AddVBFile.
Much appreciated for your help.
Labels (2)
