- Mute
- Permalink
- Report
Update a Simplify Substitute
I would creat a code to update a simplify Substitute as here (chapter "To Edit a Simplify Substitute")
but I can't code the action "Edit Simplified Assembly":
Sub ActualiseSubstitute()
' Set a reference to the active assembly document
Dim oDoc As AssemblyDocument
Dim oDef As AssemblyComponentDefinition
Dim oModelStates As ModelStates
Dim oModelState As ModelState
Dim oSubstitute() As String
Dim i As Long
Dim MyModelState As ModelState
Dim AssName As String
Set oDoc = ThisApplication.ActiveDocument
Set oDef = oDoc.ComponentDefinition
Set oModelStates = oDef.ModelStates
'Active Master state
If oModelStates.ActiveModelState.Name <> oModelStates.Item(1).Name Then
Set MyModelState = oModelStates.Item(1)
MyModelState.Activate
End If
AssName = oDoc.DisplayName
'for future if i want have the choice
i = 1
For Each oModelState In oModelStates
If oModelState.ModelStateType = kSubstituteModelStateType Then
ReDim Preserve oSubstitute(1 To i)
oSubstitute(i) = oModelState.Name
i = i + 1
End If
Next
Dim MyOccName As String
Dim oCompOccSympl As ComponentOccurrence
Dim oCompOccAssSympl As ComponentOccurrence
'Active the first Substitute
If oModelStates.ActiveModelState.Name <> oModelStates.Item(oSubstitute(1)).Name Then
Set MyModelState = oModelStates.Item(oSubstitute(1))
End If
MyOccName = MyModelState.Name
'Edit the first Substitute
Set oCompOccSympl = oDef.Occurrences.ItemByName(MyOccName & ":1")
oCompOccSympl.Edit
'Edit Simplified Assembly
Dim oSimplDoc As PartDocument
Dim oSimplDef As PartComponentDefinition
Dim oShrinkComp As ShrinkwrapComponent
Set oSimplDoc = ThisApplication.ActiveEditDocument
Set oSimplDef = oSimplDoc.ComponentDefinition
Set oShrinkComp = oSimplDef.ReferenceComponents.ShrinkwrapComponents.Item(1)
End SubCould you help me ?
- Mute
- Permalink
- Report
Hi @gaetan.lucas. I haven't really used Simplified/Shrinkwrap Assemblies as ModelStates before, but after reading down through your code, and looking at the online documentation for the associated API objects/methods/properties involved, I am making a relatively educated guess that in order for you to 'update' that ShrinkwrapComopnent, you may need to access its ShrinkwrapComponent.Definition (a ShrinkwrapDefinition), then try changing one or more of its Propertys, and maybe change them back if no changes are were actually needed, then see if that causes the 'update' to happen. If some of those properties actually need to change, do so. That is similar to 'editing' it through the dialog, but by code.
Wesley Crihfield
(Not an Autodesk Employee)
