04-05-2023
07:21 AM
- Mute
- Permalink
- Report
04-05-2023
07:21 AM
You will likely need a update snippet for the assembly and possibly a rebuild all. If you carry out the task without code can you write down the exact sequence of events you do? This includes entering into documents, hitting update and or rebuild all.
See help file for assembly update and Assembly Rebuild
You will find the same for the PartDocument. Changing the parameters of the sketch will likely need a part update to happen.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
