03-31-2023
06:58 AM
- Mute
- Permalink
- Report
03-31-2023
06:58 AM
Can anyone solve this code to create a rectangle using iLogic?
It tells me the 'Origin' on 'PlanarSketch' not found.
' Get the active document Dim invDoc As Inventor.Document = ThisApplication.ActiveDocument ' Get the active sketch plane Dim sketchPlane As PlanarSketch = invDoc.ComponentDefinition.Sketches.Add(invDoc.ComponentDefinition.WorkPlanes.Item(3)) ' Define rectangle dimensions Dim rectangleWidth As Double = 500 Dim rectangleHeight As Double = 500 ' Set the origin of the sketch plane to (0,0,0) sketchPlane.Origin = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0) ' Create the rectangle Dim startPoint As SketchPoint = sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(0, 0)) Dim endPoint As SketchPoint = sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(rectangleWidth, rectangleHeight)) Dim line1 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(startPoint, sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(rectangleWidth, 0))) Dim line2 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(line1.EndSketchPoint, endPoint) Dim line3 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(endPoint, sketchPlane.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(0, rectangleHeight))) Dim line4 As SketchLine = sketchPlane.SketchLines.AddByTwoPoints(line3.EndSketchPoint, startPoint) ' Update the sketch sketchPlane.Update()
