03-31-2023
06:40 AM
- Mute
- Permalink
- Report
03-31-2023
06:40 AM
Thanks @WCrihfield
What is the syntax for accessing the other columns in the Table?
The original from your post:
Dim oCell As iPartTableCell = oRow.Item("Member")
Here's a section of the Table showing some of the headings:
Replacing "Member" in the code below with one of the other Table column headings results in an error:
Dim oCell As iPartTableCell = oRow.Item("Part Number")Dim oCell As iPartTableCell = oRow.Item("c_Part_Nº")Dim oCell As iPartTableCell = oRow.Item("Stock Number")
This is the full code (I changed line 4 to use the member selected):
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oFactory As iPartFactory = oPDef.iPartFactory
Dim oRow As iPartTableRow = oFactory.DefaultRow
Dim oCell As iPartTableCell = oRow.Item("c_Part_Nº") '"Member" is the Heading of the iPartTableColumn
Dim oMember As String = oCell.Value
MsgBox("oMember = " & oMember, vbInformation, "iPart Row Member")
And also thanks @Michael.Navara
As you can see from my question above, I'm still struggling a bit on the structure & how the function works.
I'll try your code once I've understood the issue above.
