arkelec
686 Views, 5 Replies
iLogic to Read & Use an iPart Table Value
I want to read & use the value from a specific column in the iPart Table for the current iPart member.
Having spent an hour trying to understand the structure/syntax, I'm at a loss.
By way of example, how to read & use the text in the 'Member' column for the currently selected iPart member?
I want to read that value & add some additional text.  The adding of text I can do, but I can't see how to get the value from the Table.
Is it correct to say that 'Member' is a Project iProperty (as opposed to a Custom iProperty)?
Thanks in advance.
