EhabElsheikh
186 Views, 1 Reply
Identify Import Revit file elements with specific shared parameter in Autodesk Inventor
I want to import Revit file into Autodesk Inventor environment but each element inside Revit file has element ID which I can't change it. also, Revit elements tagged with shared parameters inside Revit, and I want to replace element ID or replaced with specific shared parameter to be bodies name in inventor.
Cadkunde.nl
in reply to: EhabElsheikh
Maybe you can attach a revit file to your message?
Then I could take a look if I can find Element ID
