03-29-2023
01:42 PM
- Mute
- Permalink
- Report
03-29-2023
01:42 PM
Hi Ben,
Thanks for the additional info a little easier to see what you have. Can you replace the key dimensions with user parameters? If so you can then either drive them directly through the form or indirectly if parameters are in a different part such as your sheetmetal parts or master sketch part. You should be able to find the parameters in the ilogic editor then add and drive all the measurements if you want to group by model type etc.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
