- Mute
- Permalink
- Report
Hi Alan,
yes, as shown below. the frame is constructed using a 3D sketch and frame generator.
the box section profiles are not standard and i have added these via the author feature and used frame generator to assemble them. the corner pieces are added to my content center and assemble via iMates flush outside faces with the box section. The 2 of center posts are also frame generator. offset from the 3D sketch.
in terms of iLogic, i would like to set this up to be modified quickly in terms of the 3 main outside dimensions @ 2100mm, 1600mm, and 800mm. Further to this the previous image i sent has panels assembled. i assume i'd be able to use iLogic so that when the main outside dimensions change the panel sizes change accordingly.
Kind Regards,
Ben
