- Mute
- Permalink
- Report
Can you give a little more info as to how you have currently constructed the model? Is it currently an assembly? Can you share a very simple file set of the .ipt and .iam that make up the assembly? Ensure to use pack and go and you can attach as a zip compressed folder. Use squares and circles or remove confidential detail if your actually assembly is not shareable as is. Without knowing your current approach there is multiple routes that can be taken.
Depending on how you approach this you can use as little ilogic or as much as you want. Is there any skeletal model controlling the frame size?
There is a dedicated forum for ilogic questions here but this might be a good place for now where you can get advice on modelling techniques from the experts with or without ilogic.
Or if this helped you, please, click (like)
Regards
Alan
