chris
162 Views, 0 Replies
Looking for a rule that will allow me to "save a copy as" an active assembly (with parts) within the assembly
I have an assembly of parts that i want to use as a template, but I don't want the user to have to use Copy Design or Design Assistant in order to save out the configured template... is there a already existing code  that would allow me to take an active assembly, "run the rule" and it would then prompt the user to "save a copy as", choose a file9s) location and then allow the user to rename the assembly and parts to the new part number...? (from within the the active assembly)?
