03-13-2023
10:39 PM
- Mute
- Permalink
- Report
03-13-2023
10:39 PM
Could you supply the full code accessing the worksheet?
The error "Object reference not set to an instance of an object.". Suggests that your not able to access an object so the next question is which object? You will need to check the work sheet then the range and so on.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
