WCrihfield
in reply to: MatthiasMinich
Interesting find.  I am able to reproduce that same behavior, both manually, and by code.  Seems like a bug, because it should not be linked that way.  It doesn't even seem to care how you have the DVR's (DesignViewRepresentations) set-up, either on the parent assembly side, or on the source component assembly side.  What version of Inventor are you using?  I'm currently using 2022.4.
Wesley Crihfield
(Not an Autodesk Employee)
