MatthiasMinich
369 Views, 6 Replies
Change visibility of origin work plane at occurrence level
there is a difference when handling "user defined workplanes" and "origin work planes". It is not possible to change the visibility of a origin work plane only in the occurrence level. Modifying the "origin work plane proxie" always changes the parent document. whereas a "user defined work plane" can be shown only in a occurrence level.
Please check the sample code below. Select a component (with a user defined work plane) in a assembly document. When the code is executed work planes (1-3) are shown in all occurrences, but the following work planes (4-...) are visible only in the selected occurrence, as desired.
Is there a work around to change the visibility of a origin work plane only at an occurrence?
I'm using Autodesk Inventor 2019
Best,
Matthias
Public Sub Test_WorkPlane_Visible()
    Dim oApp As Inventor.Application
    Set oApp = ThisApplication
    If oApp.ActiveDocumentType <> kAssemblyDocumentObject Then Exit Sub
    Dim oDoc As Inventor.AssemblyDocument
    Set oDoc = oApp.ActiveDocument
    Dim oOcc As Inventor.ComponentOccurrence
    Dim Item As Object
    For Each Item In oDoc.SelectSet
        If Item.Type = Inventor.kComponentOccurrenceObject Then
            Set oOcc = Item
            Dim i As Long
            For i = 1 To oOcc.Definition.WorkPlanes.Count
                Dim oWorkPlane As Inventor.WorkPlane
                Set oWorkPlane = oOcc.Definition.WorkPlanes.Item(i)
                Dim oWorkPlaneProxie As Inventor.WorkPlaneProxy
                Call oOcc.CreateGeometryProxy(oWorkPlane, oWorkPlaneProxie)
                oWorkPlaneProxie.Visible = Not (oWorkPlaneProxie.Visible)
            Next i
        End If
    Next
End Sub
