This iLogic rule will give you the name of the active ribbon tab (in the active ribbon)
For Each ribbon As Ribbon In ThisApplication.UserInterfaceManager.Ribbons
    If (Not Ribbon.Active) Then Continue For
    For Each ribbonTab As RibbonTab In Ribbon.RibbonTabs
        If (RibbonTab.Active) Then
            MsgBox(String.Format("Ribbon tab '{0}' in ribbon '{1}' is active",
				RibbonTab.DisplayName, Ribbon.InternalName))
        End If
    Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
