WCrihfield
in reply to: mcloughlin_b
Hi @mcloughlin_b.  This sounds like you should be able to use SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, instead of SelectionFilterEnum.kAssemblyOccurrenceFilter.  However, that one usually just wants to focus on part type components, so it is challenging, if not impossible in certain situations to use on the regular model screen for selecting a sub-sub assembly.  In some quick testing, I was able to select a sub-sub assembly using either of those two selection filters, when I selected the browser node for it, from the model browser tree, instead of selecting it on the model screen.  That is one fairly painless workaround.
Wesley Crihfield
(Not an Autodesk Employee)
