alan.wedge
in reply to: WCrihfield
one small issue worth noting it that if the pdf is open by someone else the export fails but there is no notification that the export failed, it looks like it worked. the easiest solution is to just check if i can delete the pdf but im wondering if there is a way for the code to catch the failure?
