op_thorsager
in reply to: WCrihfield
I am just getting off work in a few mins, so will have to read about the use of NameValueMap, the posted rule is shortened by about 180 lines, but these were mostly just subroutines doing the same thing as the CopyParts sub, but with a few different components(mostly to skip the supressed components if any), this tool is the only thing i've been working on the past month, and currently sitting at about 750lines split into multiple rules, which luckily all works as intended, so i don't have to mess around in them. The only one i just cant get to work is the model reference updater, i found a few ones on different forums, but they all use a file dialog, but since i already have the path where the new components are, then i feel like its a waste of time to have the user run through each component via a file dialog haha
Thanks alot for the help so far, but i don't have more time today to try and wrap this up (fixed hours employed), so i'll get back to you tomorrow :slightly_smiling_face:
