- Mute
- Permalink
- Report
@WCrihfield @raith-mb so just to get this right.
I count the items in the rule which exports the assembly and opens the drawing, then replace the references using Rolan's code?
this is an example of my export/copy code. this is run from the initial assembly(where you start)
Imports System.Windows.Forms
Sub Main
Export
CopyParts
CopyDrawing
CopyXLS
End Sub
Sub CopyXLS
Dim xspec As String = Parameter("Filename")
Dim PartRes As String
GoExcel.Open(xspec, "Tool")
PartRes = PathO & Parameter("FileNaming") & ".xlsx"
GoExcel.Save()
System.IO.File.Copy(xspec, PartRes)
End Sub
Sub CopyParts
Dim OccCrossbar As ComponentOccurrence = Component.InventorComponent("Crossbar")
Dim OccVeneer As ComponentOccurrence = Component.InventorComponent("Veneer")
Dim OccCloth As ComponentOccurrence = Component.InventorComponent("Cloth")
Dim OccExCross As ComponentOccurrence = Component.InventorComponent("ExCross")
Dim OccInsBattCut As ComponentOccurrence = Component.InventorComponent("InsulationBatt_cut")
Dim OccInsBattFull As ComponentOccurrence = Component.InventorComponent("insulationBatt_full")
Dim OccCpanel As ComponentOccurrence
If cutout_sqr = True Then
OccCpanel = Component.InventorComponent("CutoutPanel")
Else If cutout_sqr = False Then
End If
Dim CrossbarFFN As String = OccCrossbar.Definition.Document.fullfilename
Dim VeneerFFN As String = OccVeneer.Definition.Document.fullfilename
Dim ClothFFN As String = OccCloth.Definition.Document.fullfilename
Dim ExCrossFFN As String = OccExCross.Definition.Document.fullfilename
Dim InsBattFullFFN As String = OccInsBattFull.Definition.Document.fullfilename
Dim InsBattCutFFN As String = OccInsBattCut.Definition.Document.fullfilename
Dim CpanelFFN As String
CpanelFFN = OccCpanel.Definition.Document.fullfilename
End If
CpFile(CrossbarFFN, Path3D & System.IO.Path.GetFileName(CrossbarFFN))
CpFile(VeneerFFN, Path3D & System.IO.Path.GetFileName(VeneerFFN))
CpFile(ClothFFN, Path3D & System.IO.Path.GetFileName(ClothFFN))
CpFile(ExCrossFFN, Path3D & System.IO.Path.GetFileName(ExCrossFFN))
CpFile(InsBattFullFFN, Path3D & System.IO.Path.GetFileName(InsBattFullFFN))
CpFile(InsBattCutFFN, Path3D & System.IO.Path.GetFileName(InsBattCutFFN))
CpFile(CpanelFFN, Path3D & System.IO.Path.GetFileName(CpanelFFN))
End If
TopDoc.SaveAs(NewAsmFileFFN, False)
Component.Replace("Crossbar", Path3D & System.IO.Path.GetFileName(CrossbarFFN), True)
Component.Replace("Veneer", Path3D & System.IO.Path.GetFileName(VeneerFFN), True)
Component.Replace("Cloth", Path3D & System.IO.Path.GetFileName(ClothFFN), True)
Component.Replace("ExCross", Path3D & System.IO.Path.GetFileName(ExCrossFFN), True)
Component.Replace("insulationBatt_full", Path3D & System.IO.Path.GetFileName(InsBattFullFFN), True)
Component.Replace("InsulationBatt_cut", Path3D & System.IO.Path.GetFileName(InsBattCutFFN), True)
Component.Replace("CutoutPanel", Path3D & System.IO.Path.GetFileName(CpanelFFN), True)
End If
End Sub
Sub CopyDrawing
Dim OrgDrwFFN As String = Replace(OrgAsmFileFFN, ".iam", ".dwg")
Dim NewDrwFFN As String = Path2D & parameter("FileNaming") & ".dwg"
Dim OrgDrwDoc As DrawingDocument = ThisApplication.Documents.Open(OrgDrwFFN)
OrgDrwDoc.Close(True)
If System.IO.File.Exists(OrgDrwFFN) Then
CpFile(OrgDrwFFN,NewDrwFFN )
Else
MessageBox.Show("No existing dwg was found")
Exit Sub
End If
Dim NewDrwDoc As DrawingDocument = ThisApplication.Documents.Open(NewDrwFFN)
Dim oFileDesc As FileDescriptor = NewDrwDoc.ReferencedFileDescriptors(1).DocumentDescriptor.ReferencedFileDescriptor
oFileDesc.ReplaceReference(NewAsmFileFFN)
NewDrwDoc.Update()
End Sub
Dim Path3D As String
Dim Path2D As String
Dim PathO As String
Dim TopDoc As Document
Dim OrgAsmFileFFN As String
Dim NewAsmFileFFN As String
Sub Export
Parameter.UpdateAfterChange = True
Dim filePath As String
Dim subFolderName As String
TopDoc = ThisDoc.Document
OrgAsmFileFFN = TopDoc.FullFileName
' Prompt the user to select the file location
subFolderName = parameter("FileNaming")
Dim FolderBrowserDialog1 As New FolderBrowserDialog
If FolderBrowserDialog1.ShowDialog() = DialogResult.OK Then
filePath = FolderBrowserDialog1.SelectedPath
' Create the subfolder
Path3D = filePath & "\" & subFolderName & "\3D\"
Path2D = filePath & "\" & subFolderName & "\2D\"
PathO = filePath & "\" & subFolderName & "\"
If Not IO.Directory.Exists(filePath & "\" & subFolderName) Then
IO.Directory.CreateDirectory(Path3D)
IO.Directory.CreateDirectory(Path2D)
End If
End If
parameter("Location") = filePath & "\" & subFolderName
iProperties.Value("Custom", "Location") = parameter("Location")
NewAsmFileFFN = Path3D & subFolderName & ".iam"
End Sub
Sub CpFile(Source As String, Target As String)
'debug("Will copy " & Source & " to " & Target)
System.IO.File.Copy(Source, Target)
'debug(Source & " copied to " & Target)
Dim fInfo As New System.IO.FileInfo(Target)
fInfo.IsReadOnly = False
End Sub
This code only works if the original drawing file/template is located in the same folder as the original assembly(see image)
the code closes down the original assembly without saving to prevent the user from accidentally breaking the initial build. then opens up a DWG with all the sheets and so on, and a new assembly which is located within \3D\ together with the parts.
once the new drawing file is opened, the references will look like this (in this case i selected \temp\303030-2480\ as folder name and save path)
however since there are multiple sheets within this drawing document, where only a single part is present, then there will be more than just one model reference within the drawing document.
The idea is to have an event trigger which launches a rule that will replace the parts still referencing the original part files with the part files saved in the same folder as the assembly, however i will have to get the code working before setting up the trigger, just to prevent messing things up in the initial build.
If we take "cloth.ipt" for example, will this be oFile.ReferencedFileDescriptors.item(2) or how does this work exactly?
im still very new to this, and have been trying to learn the ins-n-outs of iLogic for the past month, and since i don't have anyone to teach me this, i will have to learn by trial and error/looking through forumposts/watching webinars on youtube ![]()
p.s.: @raith-mb when you say "during the copy of your IAM", are you talking about doing the count within the code i posted a bit further up in this reply?
