op_thorsager
in reply to: WCrihfield
Within the drawing document There are multiple sheets, on every sheet There Will be One part present, except for the first sheet in which the assembly lies. The reference to the assembly is updated when doing the export from assembly, however the individual parts dont update. This is where i thought i’s make the sub routines like sheet1 and sheet2.
then when have the code loop through all the sheets, get the initial model from view, then replace the reference with the part copy which is saved in \3D\
end sub and go to next sheet and repeat
alll rules are internal, since we dont utilize vault(yet) so it became a bit tedious to do revisions of the rules as external
 but to get back to the question:
drawing has multiple references, but only One model is present in sheet2
