A.Acheson
in reply to: tsp62MT3AF
The issue I would think is the replace Directory path . The path of the current file is picked up then you add in a folder. Which path is the replacement files in? Are they not all in the same folder? Check the fullfilename your supplying as it may not be logical to the file.
Regards
Alan
