02-16-2023
12:52 PM
- Mute
- Permalink
- Report
02-16-2023
12:52 PM
@GosponZ you can try something like this. It is a slight modification to your code. It will not error when it finds a page without a view & it will just remove all characters that are not letters or digits except for spaces.
Dim oDoc As Document = ThisDoc.Document
Dim oSheets As Sheets = oDoc.Sheets
For Each oSheet In oSheets
oSheet.Activate
Dim oView As DrawingView
Try
oView = oSheet.DrawingViews.Item(1)
Catch
'MessageBox.Show("There is no drawing view on " & oSheet.Name)
Continue For
End Try
Dim modelName As Object = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oProp As PropertySet = modelName.PropertySets.Item("Design Tracking Properties")
'ocProp = modelName.PropertySets.Item("Inventor User Defined Properties") 'Custom property set
Try
Dim oSheetName As String = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value '_
'& " " & "QTY" & " " & ocProp.Item("TTL").Value
Dim oDisplayName As String = ""
For Each letter As Char In oSheetName
If Char.IsLetterOrDigit(letter) Or Char.IsWhiteSpace(letter) Then
oDisplayName = oDisplayName & letter
End If
Next
ActiveSheet.Sheet.Name = oDisplayName
Catch
'MessageBox.Show("Couldn't change sheet name for " & oSheet.Name)
End Try
Next
oSheets(1).Activate
iLogicVb.UpdateWhenDone = True
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
