02-16-2023
12:27 PM
- Mute
- Permalink
- Report
02-16-2023
12:27 PM
Hi Alan,
I am sorry to be a pain, but I have converted everything over to where it should be in terms of the large excel file and put the parts in where they should be and it does not seem to work. I have tried to add debugging into the rule to make sure it is looking at the correct place for which it seems to but it is not replacing parts at all. This is confirmed by looking at the iproperties. Have I done something wrong?
Dim AsmDoc As AssemblyDocument = ThisDoc.Document
Dim CompDef As AssemblyComponentDefinition = AsmDoc.ComponentDefinition
Dim ExcelFileLocation As String = "**************End Suction Pump Drawings\Pumps\Pump_Layout_Spreadsheet.xlsx"
'Automatic setting of Pump Model.
MultiValue.List("PumpModel") = GoExcel.CellValues(ExcelFileLocation, "Sheet1", "A2", "A250")
'Intial List creation to ensure list is not blank on creation.
If PumpModel = "" Then : PumpModel = MultiValue.List("PumpModel").Item(0) : End If
Dim PumpModelRow As Integer = GoExcel.FindRow(ExcelFileLocation, "Sheet1", "Pump Model", "=", PumpModel)
Logger.Debug(PumpModelRow)
For Each Occ As ComponentOccurrence In CompDef.Occurrences
Dim Path As String = System.IO.Path.GetDirectoryName(Occ.Definition.Document.FullFileName)
Logger.Debug(Path)
Select Case Occ.Name
Case "Volute"
Try
Occ.Replace(Path & "\Volutes\" & GoExcel.CurrentRowValue("Volute"), False)
VoluteModel = GoExcel.CurrentRowValue("Volute")
' Logger.Debug(VoluteModel)
Catch
End Try
Case "Bellhousing"
Try
Occ.Replace(Path & "\Bellhousings\" & GoExcel.CurrentRowValue("Bellhousing"), False)
BellhousingModel = GoExcel.CurrentRowValue("Bellhousing")
' Logger.Debug(BellhousingModel)
Catch
End Try
Case "Motor"
Try
Occ.Replace(Path & "\Motors\" & GoExcel.CurrentRowValue("Motor"), False)
MotorModel = GoExcel.CurrentRowValue("Motor")
' Logger.Debug(MotorModel)
Catch
End Try
End Select
Next
