02-15-2023
12:54 PM
- Mute
- Permalink
- Report
02-15-2023
12:54 PM
This can vary, if your using models created from the same part file there is more chance the constraints stick together when you use occurrence replace. If not what you will need is to use the origin planes and axis as much as possible avoiding proxy faces etc. The reason becomes clear later when you look at the code created using Components.Constraints.add. See below example focusing on the constraint.Insert section, you don't need the addding sections as your already replacing the occurrence. You will need to supply the occurrence names of each part and any proxies edges/faces used.
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
