A.Acheson
in reply to: tsp62MT3AF
Here is a method to do this. It will rely on finding a filename within a column and then with the new row determined by the form (parameter change) select a new file name and replace this occurrence. Note replacing occurrence will need a fullfilename, path and filename including extension.
Dim asmDoc As AssemblyDocument = ThisDoc.Document
Dim compDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
Dim Occs As ComponentOccurrences = compDef.Occurrences
Dim excelFileLocation As String = "********\End Suction Pump Drawings\Pumps\Pump Layout Spreadsheet Test.xlsx"
'Automatic setting of Pump Model.
MultiValue.List("PumpModel") = GoExcel.CellValues(excelFileLocation, "Sheet1", "A2", "A10")
'Intial List creation to ensure list not blank on creation.
If PumpModel = "" Then
	PumpModel = MultiValue.List("PumpModel").Item(0)
End If
Dim NewRow1 As Integer = GoExcel.FindRow(excelFileLocation, "Sheet1", "Pump Model", "=", PumpModel)
If NewRow1 = -1 Then MessageBox.Show("Error retrieving row, exiting", "Error Check") : Return
Dim OldFileName1 As String
Dim NewFileName1 As String
For Each Occ As ComponentOccurrence In Occs
	Dim FileName As String = System.IO.Path.GetFileName(Occ.Definition.Document.FullFileName)
	Dim Path As String = System.IO.Path.GetDirectoryName(Occ.Definition.Document.FullFileName)
	'[Occurrence(1) replace
	'Check if occurrence filename is in the correct column, so we change the right occurrence.
	Dim OldRow1 As Integer = GoExcel.FindRow(excelFileLocation, "Sheet1", "Volute", "=", FileName)
	If OldRow1 = -1 Then MessageBox.Show("Error retrieving row, exiting", "Error Check") : Return
	OldFileName1 = GoExcel.CellValue(excelFileLocation, "Sheet1", "B" & OldRow1)
	If FileName = OldFileName1 Then
		NewFileName1 = GoExcel.CellValue(excelFileLocation, "Sheet1", "B" & NewRow1)
		Logger.Info("Path: " & Path)
		Logger.Info("NewRow: " & NewRow1)
		Logger.Info("OldRow: " & OldRow1)
		Logger.Info("FileName: " & FileName)
		Logger.Info("OldFileName: " & OldFileName1)
		Logger.Info("NewFileName: " & NewFileName1)
		Try
			Occ.Replace(Path & "\" & NewFileName1, False)
		Catch
		End Try
	End If
	'[Occurrence(2) replace
		'Copy first structure and rename variables
Next
Regards
Alan
