A.Acheson
in reply to: CarterDraws
The only way this might work is with  prompted entry. As this can be used per sheet basis. It gets messy quickly however. The alternative is to switch to using the revision block object. This is a dedicated object for revision that would live out side of the title block. You can target the revision block per sheet. Just some ideas.
Regards
Alan
