CarterDraws
in reply to: A.Acheson
"Bearing mind iproperties are document based and not sheet based therefore you may need multiples in your document."
A solid point. I believe this means this is not the route I want to go. As I will never know the number of sheets needed per document from job to job. That is part of the reason I am looking for a global document wide update method and a per sheet update method for revisions.
